Removal of water pump casing
02-apr
As the hose at work is out of action I haven't been able to wash the bike today so am working from memory a bit.
I think all the screws on the casing can be removed but, as I want to renew the pump bearings, has anyone managed to remove the casing without dropping the sump guard - can it be wiggled past the rubber protection sandwiched between crankcase and sumpguard?
As the guard is now a lot more bent than it was when I last removed it I anticipate even more of a battle to get it back in position.
Thanks
