merlin4x4 Posted January 16, 2011 Report Share Posted January 16, 2011 hi.all. i am new to this forum and am hoping some of you may be able to help me. i have a montesa cota 247 which i have owned for the last twenty years or so, and the last 15 years it has been in bits and boxes in the garage. having recently moved it nearly went to the scrapman but i decided to keep it in the end. i have started to put it back to gether again to se if i can get it running. so far so good but i now need to put some oil in the engine and gear box but i dont no what type and amount to put in. so far i have discoverd it is a 1972 model. any help would be of great help as this is a classic bike and it deservs better than sitting in a pile of bits just rotting away. many thanks stephen. Quote Link to comment Share on other sites More sharing options...
dandukedaisy Posted January 16, 2011 Report Share Posted January 16, 2011 Hi Stephen, I have a 1971 cota 247. I use a 40:1 fuel/oil ratio.....Castrol 2 stroke oil. For the clutch I use 7Floz of ATF (automatic transmission fluid). For the gearbox I use 10.5 Floz of SAE 90w. For the Forks I use 6.5Floz of SAE 30w per leg. Hope this helps Dan. Quote Link to comment Share on other sites More sharing options...
merlin4x4 Posted January 19, 2011 Author Report Share Posted January 19, 2011 Hi Stephen, I have a 1971 cota 247. I use a 40:1 fuel/oil ratio.....Castrol 2 stroke oil. For the clutch I use 7Floz of ATF (automatic transmission fluid). For the gearbox I use 10.5 Floz of SAE 90w. For the Forks I use 6.5Floz of SAE 30w per leg. Hope this helps Dan. cheers dan that helps alot. just need to get some oil now and a couple of other bits and then see if it will start for the first time in years. thanks stephen Quote Link to comment Share on other sites More sharing options...
keychange Posted January 20, 2011 Report Share Posted January 20, 2011 (edited) Recommended fuel ratio is 4% so 25:1 - new oils are good but I don't have problems with fouling at that mix.Original manual statesGearbox SAE-90 - 300ccClutch SAE 10 W30 200ccForks SAE 20 or 30 190cc ( most people appear to use Auto Trans Fluid ATF) I used it last change and I think it is an improvement.Send me message I can shoot you a copy of the useful pages of the manual - most is in Spanish Edited May 13, 2014 by keychange Quote Link to comment Share on other sites More sharing options...
alwsmith Posted May 12, 2014 Report Share Posted May 12, 2014 Oh it sounds so familiar. My story is almost exactly the same (though to be honest, mine was never going anywhere). My query is,is it possible to check the oil levels ? I cannot remember. Quote Link to comment Share on other sites More sharing options...
keychange Posted May 13, 2014 Report Share Posted May 13, 2014 no not really Quote Link to comment Share on other sites More sharing options...
kingscorpion Posted May 13, 2014 Report Share Posted May 13, 2014 Just a small comment on gearbox oil: it should be API GL4. API GL5 oils will corrode the "yellow metals" inside the gearbox because of their sulfur additives. Quote Link to comment Share on other sites More sharing options...
Wyoben Posted June 26, 2019 Report Share Posted June 26, 2019 I have a 72 King Scorpion ,I'm 61 years young ,actually have 2 of them , riding one and restoring the other contemplating putting it in my living room so I can drool over it ... I had this same bike when I was a teeny Bopper in the 70's...anyway , I need to completly drain and refil engine/trans fluids , any tips on how and where to get all the old lubricants evacuated , and where to fill same , thanks from dirt Bike heaven WYOMING Ben Quote Link to comment Share on other sites More sharing options...
