monty_jon Posted January 19, 2011 Report Share Posted January 19, 2011 What's the best oil for a 250 beamish? Is ATF ok? Quote Link to comment Share on other sites More sharing options...
beamish owners club Posted January 20, 2011 Report Share Posted January 20, 2011 Hi Jon, I have run ATF in my Suzuki gearbox without any problems at all. The beauty of ATF is it is so cheap you don't mind changing it often which is good for the gearbox and the clutch. Quote Link to comment Share on other sites More sharing options...
beamish owners club Posted October 21, 2011 Report Share Posted October 21, 2011 Having said that ATF is fine in the gearbox on a Beamish, I have found that on my 325 outfit the clutch judders under the load of 2 people and a chair. It is much better with using the recommended 20/50. I had no problems with ATF in my 250 solo though. Quote Link to comment Share on other sites More sharing options...
monty_jon Posted October 22, 2011 Author Report Share Posted October 22, 2011 Having said that ATF is fine in the gearbox on a Beamish, I have found that on my 325 outfit the clutch judders under the load of 2 people and a chair. It is much better with using the recommended 20/50. I had no problems with ATF in my 250 solo though. Thanks for the update. I Quote Link to comment Share on other sites More sharing options...
