monty_jon Posted January 21, 2011 Report Share Posted January 21, 2011 Any advice on how to get up large steep muddy climbs? I seem to get 2/3 the way up the lose traction (I Quote Link to comment Share on other sites More sharing options...
t-shock 250 Posted January 21, 2011 Report Share Posted January 21, 2011 3rd and 4th gears are your friends. Quote Link to comment Share on other sites More sharing options...
chewy Posted January 21, 2011 Report Share Posted January 21, 2011 What on a Beamish? best advice as you are near go and watch Steve Saunders the master of hills, I think his secret is not to anticipate grip, tis all in the legs Quote Link to comment Share on other sites More sharing options...
benbeta23 Posted January 21, 2011 Report Share Posted January 21, 2011 (edited) Get your body right down on the bike, Keep the throttle on constant, Don't shut off until your certain you've made it. & if you have to, slip the clutch for a second. Edited January 21, 2011 by BenBeta23 Quote Link to comment Share on other sites More sharing options...
monty_jon Posted January 21, 2011 Author Report Share Posted January 21, 2011 Cheers guys, I Quote Link to comment Share on other sites More sharing options...
pete_scorpa3 Posted January 21, 2011 Report Share Posted January 21, 2011 Keep your feet on the pegs, as soon as you dab you take the wieght off the rear tyre and it has less grip. Quote Link to comment Share on other sites More sharing options...
beta_trials Posted January 22, 2011 Report Share Posted January 22, 2011 Keep your weight farther back on the rear tire and slip your clutch to maintain constant throttle and maintain momentum through the climb. Dont make sudden throttle adjustments as you can loose traction. 3rd and 4th gear are great to work with. Best way to learn is practice practice practice. Quote Link to comment Share on other sites More sharing options...
trialsmotopat Posted January 25, 2011 Report Share Posted January 25, 2011 Keep your feet on the pegs, as soon as you dab you take the wieght off the rear tyre and it has less grip. bwahahaha this is trials Quote Link to comment Share on other sites More sharing options...
neil king Posted January 25, 2011 Report Share Posted January 25, 2011 bwahahaha this is trials Yes, and we all put our feet down sometimes. Quote Link to comment Share on other sites More sharing options...
trialsmotopat Posted January 25, 2011 Report Share Posted January 25, 2011 Yes, and we all put our feet down sometimes. he just said to not to or you will loose grip when you dab. So just don't do it, okay If it was as easy as not putting your feet down, and we all did it (not putting a foot down) no-one would have a problem getting over any obstacle and we'd all be pretty good trials riders, eh? The reply I found amusing was like asking for tips on how to water ski and getting told to not fall in the water. I will get back under my rock if no-one shares my POV Quote Link to comment Share on other sites More sharing options...
copemech Posted January 26, 2011 Report Share Posted January 26, 2011 I might suggest an alternat method, all depending upon the hill,and the run-up. If one has a bit of a run area, accelerate as hard and quickly as one can at the bottom, getting high revs and storing some energy in the bike to carry you up without spinning or having to apply power over slippry roots and such using then steady power or none at times. Momentum can get you a long way toward the top! And with less effort! Quote Link to comment Share on other sites More sharing options...
