maintenance
andymower
silicone spray but mind dont go near the brakes.
I was told remove flywheel cover to let magneto dry out.Clean chain & lube.And give electrics a spray with wd40. Remove air filter & clean & reoil.And give every nut & bolt the once over too make sure there tight.
<genuine question> why not the plastics?
I've used WD40 on the plastics on my bike, shines them up and keeps muck from sticking. I usually am very careful to spray a rag and wipe on to keep overspray off certain components, like when near the area of naughty bits like brake calipers and disks.
Jon
WD 40 will remove the adhesive from your decals on plastics, even applied lightly with a cloth mine started lifting after a while. I now use wd40 on bike and silicone spray to shine plastics and help washing mud off
Is this the wd40 thread now?
Send your Mrs to Asda with a few quid extra, 250ml cans of WD40 are only £1 each at the moment. I bought 5 tins on Thursday. Bargain!
They are usually on the isle with car or decorating stuff.
Edited by wasntme
