help wiring diagram neded
kenww
does anyone have a wiring diagram for an ossa explorer or at least non battery bike with lights,have made a loom tested it with a battery,but dont know if I need a rectifier/regulator,nor sure of connections from stator.
Do you know what system is is for sure. Thoughts being you may well need a regulator tied into the lighting circuit to keep from popping lamps at revs, but I cannot figure you need a rectifier with no battery or fan. Could be 6V lighting? Most regulators ar e just a simple "T" shunt to earth for the excess voltage. Just got to get the right one!
