scorpa sy fan turning too slow
hamtrux
Hi, newbie here.I am seeking some advice on the problem I have with my 04 scorpa, it boiled up last time out and spat steam from breather pipe on the rad,bike starts and runs fine.so, I have tested the fan with a 12 volt battery and it spins super fast.also, I bridged the wires to the thermostat(removing it from the equation) and started the bike..this would make the fan run ye??not on my bike, it only turns at a very slow speed and I can stop it with my finger.I think its voltage or current related...it defo gets some but not near enough to cool the bike.coolant level is fine and mixed correctly.also, my headlight stopped working,not checked that at all as yet
any advice of what to check next?regulator maybe?
thanks for reading.
Are there any cables odstructing it?
Thanks folks, problem solved, some of the wiring at the headlight is abit ropey and needs tidying this some how stppoed my fan from running...av solved the problem( overheating) and i now need t remove a switch up at the headlight.....
