caravan_monster Posted January 28, 2011 Report Share Posted January 28, 2011 Went to fetch out my 2000 315r for some friday afternoon practice, and there was a pool of oil under the rear shock (definitely not from the gearbox, before anyone asks)Have taken it to a long established (mx/enduro) suspension specialist. He wasn't too sure, but said he'd have a look and let me know. Does anyone know of somewhere that can do the work on these shocks ? Or do you really have to replace the shock when it needs servicing ? (seems like a rip off to me) If a replacement shock is required, is there a better aftermarket item available in a similar price bracket ? Quote Link to comment Share on other sites More sharing options...
fastducs Posted January 28, 2011 Report Share Posted January 28, 2011 No, you don't have to replace the shock just because it is leaking. I had mine rebuilt by a suspension specialist, and it wasn't that expensive. Furthermore, the damping adjuster on mine was broken internally, so he machined a small batch of replacements because you can't buy them from Showa. If your adjuster is seized or broken, you can buy one from my suspension guy: http://www.computrackboston.com/ If you want to replace your rear shock, Lewisport carries TRP shocks for Montesa, Sherco, GG, and Beta Evo: http://www.lewisportusa.com/Images/TRPshocker_a.jpg http://www.lewisportusa.com/parts_wheels.htm Quote Link to comment Share on other sites More sharing options...
caravan_monster Posted January 31, 2011 Author Report Share Posted January 31, 2011 Thanks fastducs ! A rebuildable aftermarket shock like that TRP looks like the way to go if I end up having to replace. I'm not paying over Quote Link to comment Share on other sites More sharing options...
for artie Posted January 31, 2011 Report Share Posted January 31, 2011 The Showa is easily re-built and will feel like new when done so. Quote Link to comment Share on other sites More sharing options...
barnesy Posted February 1, 2011 Report Share Posted February 1, 2011 Thats useful to know, can anyone recommend a shop to do it (in UK) as I reckon mine needs doing. Cheers B Quote Link to comment Share on other sites More sharing options...
barfy Posted February 5, 2011 Report Share Posted February 5, 2011 I've used Brook Suspension (http://brooksuspension.co.uk/index.html) to remove the expansion tank and rebuild a Showa RTL shock.. Quote Link to comment Share on other sites More sharing options...
caravan_monster Posted February 5, 2011 Author Report Share Posted February 5, 2011 Got mine back from Pro Racing repaired and ready to go It sounds like these shocks are economically viable to service so long as the bladder has not been damaged, but you can't tell if it is ok without dismantling the shock. Quote Link to comment Share on other sites More sharing options...
barnesy Posted February 7, 2011 Report Share Posted February 7, 2011 Thanks for the info... now I know where to take it! Ta B Quote Link to comment Share on other sites More sharing options...
