Swing arm removal
lewisjambo123
Hi I assume you have also removed the rear shock assembly? If so the swingarm should just drop out. Getting the pivot shaft out is usually the hard part.
I removed mine just the other day so let me know if you are still having problems - I'll try to help
Once you've removed the pivot shaft from the swing arm how do you get the swing arm off on a ty 250 mono ?
Cheers
Edited by ps1000
Hi - I certainly didnt have to use any force - it just dropped out. Have also just replaced it and again it fitted into place without any effort
Have you had any luck getting yours out yet ?
Hi I remouved the pivot shaft surprisingly easily but the swing arm doesent seem to come out do you need to aply some force ?
Cheers
