godzilla Posted February 1, 2011 Report Share Posted February 1, 2011 (edited) Im having trouble fitting the bearing to the bottom yoke, has anyone got any tips, its real tight and i dont wat to damage the finnish of the yoke. its properly pi**ing me off now.. Bearing i a 32005, Edited February 1, 2011 by godzilla Quote Link to comment Share on other sites More sharing options...
mikee Posted February 1, 2011 Report Share Posted February 1, 2011 (edited) I did one of these last week on a sherco.. I put the yoke in the feezer overnight to get it really cold. Then just before fitting i droped the bearing in boilling hot water for a couple of minutes. The bearing fell into place easy.. Blew all the water off with a air line and regreesed with water proof greese. Al went well for me..Hope it works for you two.. Edited February 1, 2011 by MIKEE Quote Link to comment Share on other sites More sharing options...
ormplus Posted February 1, 2011 Report Share Posted February 1, 2011 puting it on with a metal pipe(exhaust pipe etc).if you dont have anything try a fast fit garage , go with a hacksaw and cut of an old piece of exhaust the same size as the bearing. Quote Link to comment Share on other sites More sharing options...
lee harris Posted February 1, 2011 Report Share Posted February 1, 2011 both of above...ensure bare metal where the bearing sits or it wont work. If it wasnt masked before painting, get yer4 wet and dry out...I use a dremel L Quote Link to comment Share on other sites More sharing options...
godzilla Posted February 1, 2011 Author Report Share Posted February 1, 2011 Cheers guys, got it on in the end. it was very very tight, i used a bit of pipe and with a good bit of persuasion from my yorkshire spanner it seated nicely. Quote Link to comment Share on other sites More sharing options...
turbo Posted February 2, 2011 Report Share Posted February 2, 2011 Cheers guys, got it on in the end. it was very very tight, i used a bit of pipe and with a good bit of persuasion from my yorkshire spanner it seated nicely. Glad you got it on ,but for next time consider putting bearing in the oven at 180 c and it should just drop on. Quote Link to comment Share on other sites More sharing options...
godzilla Posted February 2, 2011 Author Report Share Posted February 2, 2011 Glad you got it on ,but for next time consider putting bearing in the oven at 180 c and it should just drop on. That would involve me having to ask how the oven works, if i knew how the oven worked i may be forced to cook something.. Quote Link to comment Share on other sites More sharing options...
totalshell Posted February 3, 2011 Report Share Posted February 3, 2011 dont put the bearing naked in the boiling water pop it in a freezer bag and it ll have to be in more than a couple of minutes with the water boiling all the time Quote Link to comment Share on other sites More sharing options...
