basher Posted February 1, 2011 Report Share Posted February 1, 2011 bike is 2010 sherco 290 bike has been running really crap lately, reguarly stalling and not ticking over well. ive changed oils lately to PJ1 which seems to have made a difference in making it worse, but wondered if the amount of oil i use could be the probelem to why its running rubbish on tick over? im running 100ml to 5 litres which is 50:1 Quote Link to comment Share on other sites More sharing options...
wingandaprayer Posted February 2, 2011 Report Share Posted February 2, 2011 Hi, put in 80ml to 5 litres and it should run a lot cleaner, could do with a blast down a track/ field etc to clean out the exhaust, its getting worse because it is getting more coked up with oil. Hope this helps Quote Link to comment Share on other sites More sharing options...
monty_jon Posted February 2, 2011 Report Share Posted February 2, 2011 On 2/2/2011 at 12:06 AM, wingandaprayer said: Hi, put in 80ml to 5 litres and it should run a lot cleaner, could do with a blast down a track/ field etc to clean out the exhaust, its getting worse because it is getting more coked up with oil. Hope this helps I've never had any problems at 50:1 or richer (Castrol TTS) Quote Link to comment Share on other sites More sharing options...
gjbiker Posted February 2, 2011 Report Share Posted February 2, 2011 Have you had the carb off for a good clean / blow through? A 50:1 pre-mix or change of oil shouldn't cause the symptoms you're describing? GJ Quote Link to comment Share on other sites More sharing options...
copemech Posted February 2, 2011 Report Share Posted February 2, 2011 Sounds as though you may have other issues, but many here run lean and clean on 80:1 with full synth oils on the pro bikes. The excess just bogs things down and dirties it up. 62.5 for 5L. Mant punters run at 100:1 with no issue. Now admittedly, this experience is limited to probably less than a couple thousand riders over the last decade or so, but it seems to hold true. We are still waiting to see if one will actually blow up! Quote Link to comment Share on other sites More sharing options...
ormplus Posted February 2, 2011 Report Share Posted February 2, 2011 strip and clean carb. drain petrol tank and change filter. refill with 100cc to 5ltr petrol, ipone samurai fully syn. Quote Link to comment Share on other sites More sharing options...
basher Posted February 2, 2011 Author Report Share Posted February 2, 2011 carb has been cleaned, i have an inline filter between tank and fuel pump and that is changed every so often so is fine, air filter is clean. ill try 80ml mix with ipone which i was using before. i suppose i could check the plug for being crapped up, and oily. Quote Link to comment Share on other sites More sharing options...
neo Posted February 2, 2011 Report Share Posted February 2, 2011 I've never had any problems at 80:1 (Castrol TTS) .... and I think I'm tired of saying that too ....anyone that runs more synthetic oil than that JUST AIN'T LISTENING!!! Yer clean the carb .... it just has to be learnt and done on a Trials bike. Best of balance. Neo Quote Link to comment Share on other sites More sharing options...
copemech Posted February 3, 2011 Report Share Posted February 3, 2011 On 2/2/2011 at 7:12 PM, Neo said: I've never had any problems at 80:1 (Castrol TTS) .... and I think I'm tired of saying that too ....anyone that runs more synthetic oil than that JUST AIN'T LISTENING!!! Yer clean the carb .... it just has to be learnt and done on a Trials bike. Best of balance. Neo Agreed. One of the big things on a Sherco is the fact you need to keep the muff clean and free of excess buildup of oiley residue. And excess oil usage is not environmentally friendly either. Unless you are running a high speed road trial event, I cannot figure a reason for it. Neo, heard from TFT? Quote Link to comment Share on other sites More sharing options...
