Re-assembly
beeaj
Having finally got my barrel and wossner piston checked for fit it's time to re-assemble. Should the new small end bearings be lubricated with anything before assembly and what are the correct barrel and head torque settings. Also I was told the fit was a good one but to run it in carefully, should my fuel mix be on the slightly rich side when doing this?
thanks
I think a little lubing with 2T oil is the order of the day, not sure about more oil in the premix but I'd think it would be a good idea, someone more knowledgable will no doubt be along shortly. Where'd you get the piston kit from?
You could richen the mixture, if you must, by carb adjustment but does anyone do this even with a new bike? I suspect not.
Just putting more oil in the petrol weakens the carburetion causing hotter running so it is not generally advised.
thanks
Cylinder head screws_ 8 to 10 ft lbs 11 to 14 Nm
Cylinder nut__________18 to 20 ft lbs 25 to 27 Nm
I usually tighten the head capscrews by hand as most
torque wrenches don't read well at those low settings.
The trick is to heat cycle the engine (riding sessions)
a couple of times and re-torque the head fasteners. They use
copper washers to seal coolant so they will compress a little
at first and this will avoid o-ring leakage in the future.
Jon
Hi
Piston kit from Ebay,
http://cgi.ebay.co.uk/Wossner-Piston-Gas-Gas-TXT250-01-09-Sale-Price-/380297828362?pt=UK_Motorcycle_Parts&hash=item588b84580a
they have three sizes and I got the largest 72.49 which was pefect for my 2003.
Jon
Jon
Thanks for all the advise everyone
