gaz_hay Posted February 3, 2011 Report Share Posted February 3, 2011 hi, i have a ty 250, its been fitted with new clutch plates but when put in gear in morning it puls forward with the clutch in when warm theres no problems? The adjustment on lever is right out, so were do you adjust the clutch? Thanks,, Quote Link to comment Share on other sites More sharing options...
malcontent Posted February 3, 2011 Report Share Posted February 3, 2011 hi, i have a ty 250, its been fitted with new clutch plates but when put in gear in morning it puls forward with the clutch in when warm theres no problems? The adjustment on lever is right out, so were do you adjust the clutch? Thanks,, I will give you the instructions as written in the rider's handbook. A. Freeplay adjustment 1.loosen the clutch lever adjusting lock nut. 2. turn the adjuster in or out to obtain 2-3mm free play between lever and purch. B. Mechanism adjustment 1.Remove left side cover,gear lever if needed.Note position of clutch axle lever under the engine. 2.Loosen the adjusting screw lock nut and fully tighten eccentric adjusting screw.The adjuster is just in front of the gearbox sprocket. 3.Turn cable length adjuster in or out until the lever is positioned slightly behind main axle center line. 4.Back eccentric adjust screw out until axle lever shaft contacts clutch push rod inside engine.Turn adjust screw in about 1/8 turn and tighten lock nut.Readjust clutch lever to get freeplay as required. Hope this makes sense,but is taken exactly as written in the hand book. Cheers Malcontent Quote Link to comment Share on other sites More sharing options...
ducman Posted February 3, 2011 Report Share Posted February 3, 2011 Maybe your gearboxoil is too thik. Chrs:Mike Quote Link to comment Share on other sites More sharing options...
paddyrfc Posted February 7, 2011 Report Share Posted February 7, 2011 I always rock mine back and forth in top gear with the clutch disengaged to seperate the clutch plates before riding. I was use 10w oil in the gearbox and everything works perfectly. Quote Link to comment Share on other sites More sharing options...
gaz_hay Posted February 9, 2011 Author Report Share Posted February 9, 2011 Thanks, for replies sorted now cheap nasty oil was used. Quote Link to comment Share on other sites More sharing options...
