john b Posted February 4, 2011 Report Share Posted February 4, 2011 The clutch on my recently rebuilt Montesa 172 (same clutch as the 123?)won't disengage the drive, and is very heavy. Any obvious things to check before and during the ineviatable strip down !! Hopefully the Montesa guru's out there can shed some light. cheers John Quote Link to comment Share on other sites More sharing options...
woodbutcher Posted February 5, 2011 Report Share Posted February 5, 2011 LOOK IN CLASSIC TRIALS FORUM , PAGE 2 , NOV. 9TH MONTESA 242 CLUTCH , READ SCRATT Quote Link to comment Share on other sites More sharing options...
john b Posted February 5, 2011 Author Report Share Posted February 5, 2011 cheers much appreciated John Quote Link to comment Share on other sites More sharing options...
woodbutcher Posted February 7, 2011 Report Share Posted February 7, 2011 HAS FOLLOWING THAT REBUILD SEQUENCE GOT YOUR CLUTCH TO DISENGAGE ? ALSO MAKE SURE THE SMALL CLUTCH CENTRE THAT SITS OVER THE THREE LONG PINS ON SHAFT WILL MOVE EASILY INSIDE THE CLUTCH PLATE CENTRE HUB Quote Link to comment Share on other sites More sharing options...
