Fitting an older wheel on a newer bike
dveed
I've modified a 2007 Rev-3 wheel to fit an Evo. You have to make 2.25mm packers to go behind the disc (I have still used the spring washers). You have to machine the diameter of the disc down from 165mm to 160mm (or buy a new disc). The drive side spacer is OK but you need to increase the size of the disc side spacer to 14mm. Hope this helps.
