andymower Posted February 6, 2011 Report Share Posted February 6, 2011 hi every1 im just about to do a oil change but i dont no what oil to use to replace the old ive got a gas gas txt pro 280cc 2005 also is there anything else you would reccomend to do while im changing it? eg new spark plugs,air filter etc cheers for any replys andy Quote Link to comment Share on other sites More sharing options...
richt Posted February 6, 2011 Report Share Posted February 6, 2011 Use 'ATF' like Castrol TQ-D from any car spares shop, There has recently been a few threads on here for this subject. Always check over for any required maintenance. Air Filter,Chain, brake n clutch fluid, water, check tyres for sharps and bolt tightness checks. remove Brake pads and clean mud from in calipers and wheel bearings. It all helps for a worry free day out! Quote Link to comment Share on other sites More sharing options...
