drake Posted February 7, 2011 Report Share Posted February 7, 2011 Is it possible to get a short spark plug for a 2003 290? The plug currently in there is very difficult to remove, due to it's length Quote Link to comment Share on other sites More sharing options...
neo Posted February 7, 2011 Report Share Posted February 7, 2011 H Drake, Check it's a NGK BP5ES? How long have you had this bike? ....because it sound like your plug may have been fitted cross-threaded in the past. After the first turn with a spanner it should unscrew with just the tips of your fingers. Best of balance. Neo Quote Link to comment Share on other sites More sharing options...
paxdad Posted February 7, 2011 Report Share Posted February 7, 2011 Is it possible to get a short spark plug for a 2003 290? The plug currently in there is very difficult to remove, due to it's length If you go to the NGK web site they have a guide on there to tell you what the number/ letters stand for. Using the guide you can then find the equivalent plug to a BP5ES which there might be a shorter version available. I am assuming that when you said short you were indicating the amount of room to get the cap off and plug out of the cylinder head. Quote Link to comment Share on other sites More sharing options...
1oldbanjo Posted February 7, 2011 Report Share Posted February 7, 2011 Is it possible to get a short spark plug for a 2003 290? The plug currently in there is very difficult to remove, due to it's length Be sure if you get a new plug - the threaded length is the same and the electrode sticks out the same amount. If you get a plug with a shorter lenght it will not reach the combustion chamber and your performance will probably be affected. I don't know if they make a plug with a shorter porcelan section on top - and if they do will the cap you have fit the shorter top? Quote Link to comment Share on other sites More sharing options...
drake Posted February 7, 2011 Author Report Share Posted February 7, 2011 (edited) I think there is a little confusion here. The plug is fine in the thread and there is nothing wrong with it apart from acess being a little tight. I know on some dirt bikes it is possible to get the same plug, but with a shorter porcelain section. It just makes things a little easier thats all. just wondering if these plugs were available for the Sherco? On my KTM these were used and they take a regular cap Edited February 7, 2011 by Drake Quote Link to comment Share on other sites More sharing options...
ormplus Posted February 7, 2011 Report Share Posted February 7, 2011 remove the bolt holding the top of the tank.lift the tank up slightly and you will get the plug outa lot easier. Quote Link to comment Share on other sites More sharing options...
neo Posted February 7, 2011 Report Share Posted February 7, 2011 I think there is a little confusion here. The plug is fine in the thread and there is nothing wrong with it apart from acess being a little tight. Thank Christ for that .... you really had me worried there If you find a shorter plug please let us know. Best of balance. Neo Quote Link to comment Share on other sites More sharing options...
drake Posted February 8, 2011 Author Report Share Posted February 8, 2011 (edited) The shorter plugs have ecm after the numbers instead of es. Unfortunately i'm not sure if you can get them? well i can't find one anyway. You can get 7 and 8's but not 5's it seems Edited February 8, 2011 by Drake Quote Link to comment Share on other sites More sharing options...
