crak in rear brake plate
wombat
Ive found a long crack in the rear brake backing plate on my '74 TY250. It seems to be full thickness crack. Can this be welded or do I source another 1?
Hi wombat
Any decent welding firm will be able to TIG [must be TIG, mind] weld that for you. Will then be a simple matter of dressing the weld for cosmetic purposes. If you don't know of a local company, put welding services or precision engineers into Yell.com and make a few calls. Do NOT let your mate loose on it who says "No problem, I can easily gas weld that for you...."
If the crack goes through the pivot hole, make sure the bearing surface is aligned properly and be prepared to ream the hole slightly.
One more thing, might be easier to look at the ads in "Classic Dirt Bike" as I'm sure you'd find a replacement from one of the companies who advertise there.
Best wishes
Will-in-the-mud.
Hi wombat
Best wishes
Will-in-the-mud.
Will...
I have a number of a bloke not far from me, I'll be going to see him tomorrow. Thanks for your advice..Here's a pic. Cant figure out how it happened..
Be careful the brakeplate is magnesium and needs a special system to weld.Magnesium burn's very well,remember taht.
Chrs:Mike
Very easy to find on ebay, seems to be lots of them listed in the us
Tony, I have 1 on watch list now..I'll see this local bloke tomorrow. So frustrating trying to get the TY ready for the years' comps and I find it now! Better now than in the section!
