owen Posted February 9, 2011 Report Share Posted February 9, 2011 HELLO Is a TY250 twinshock engine the same as a DT250 engine, if not what is the difference? So if not, what other bikes have the same engine as the TY or a engine that will fit (different cc etc) thanks Owen Quote Link to comment Share on other sites More sharing options...
monty_jon Posted February 9, 2011 Report Share Posted February 9, 2011 (edited) HELLO Is a TY250 twinshock engine the same as a DT250 engine, if not what is the difference? So if not, what other bikes have the same engine as the TY or a engine that will fit (different cc etc) thanks Owen Im not 100% sure but I would guess the gearing & cylinder porting is different I would think the DT is closer to the early YZ rather than the TY Edited February 9, 2011 by Monty_Jon Quote Link to comment Share on other sites More sharing options...
old trials fanatic Posted February 9, 2011 Report Share Posted February 9, 2011 A DT engined TY just sold on flea bay. Wonder if the buyer knew what they were buying??? Quote Link to comment Share on other sites More sharing options...
owen Posted February 10, 2011 Author Report Share Posted February 10, 2011 (edited) So save me the mistake and explain.. whats the difference between the DT and TY engine? help Edited February 10, 2011 by Andy No Ads on forums Quote Link to comment Share on other sites More sharing options...
02-apr Posted February 10, 2011 Report Share Posted February 10, 2011 So save me the mistake and explain.. whats the difference between the DT and TY engine? help About 30mph probably. I'm not taking the P but that seems the easiest way to sum up the various differences in tuning, gearing, expansion chamber, carb size etc that would render the DT hopeless for trials use. Quote Link to comment Share on other sites More sharing options...
feetupfun Posted February 10, 2011 Report Share Posted February 10, 2011 maybe you are asking which parts are interchangable? Unfortunately for would-be parts swappers, Yamaha made quite a few changes to their 250cc dirt bike engines during the time frame that they were producing the TY250 motor, so your question would have to take into account which DT250/DT2/DT3 motor and which TY250 motor you are referring to. Many parts are interchangable but also many are not. As far as performance-oriented design differences, the TY250 motor has a much heavier magneto flywheel, similar port timing, closer gear ratios for 1,2 and 3 gears, lower compression ratio, smaller carby and very different exhaust pipe design to what was used on the DT2, DT3 and DT250ABCDEFG motors. Quote Link to comment Share on other sites More sharing options...
mattylad Posted February 11, 2011 Report Share Posted February 11, 2011 If you are talking about twin shock then the crankcases and covers are all different. Some internal parts fit Quote Link to comment Share on other sites More sharing options...
jc2 Posted February 12, 2011 Report Share Posted February 12, 2011 (edited) There are 4 different sets of crankcases, each with diff engine mounts & diff non-interchangeable clutch covers: 1) DT1/2/3, YZ A/B, 2) DT A/B (& perhaps C) 3) TY 4) DT D etc (eng mounts are close to DT A/B but slightly diff DT A/B/C/D cases are about 1" longer than TY cases, so its not a straight forward engine transplant, but I did read of somebody (foolishly, IMHO) putting a DT400 engine in a TY in USA (where else?) I think. TY stud spacing on barrel & head is same as DT250 A/B/C/D, & interchange, but diff porting, Comp Ratio Some internal cluth/primary gear/g'box parts exchange, but not all. IIRC TY A & DT A use keyed primary gear; B/C/D models for ea use splines (or vice versa) DT C/D gears were diff (wider) to DT A/B IIRC but not sure if the whole set will interchange. Don't know if shifting forks & drums are diff/same Edited February 12, 2011 by JC2 Quote Link to comment Share on other sites More sharing options...
