smallboy Posted February 11, 2011 Report Share Posted February 11, 2011 Hi all Can somebody advise me ,what the two adjusters are on top of my EVO fork legs,and what do they adjust? Cheers Quote Link to comment Share on other sites More sharing options...
02-apr Posted February 11, 2011 Report Share Posted February 11, 2011 There's been a few questions along this sort of line recently. Don't Beta issue anything with their bikes nowadays? Even Bultaco managed a small bit of card with the basic adjustments explained. Quote Link to comment Share on other sites More sharing options...
scottraining Posted February 11, 2011 Report Share Posted February 11, 2011 (edited) not positive its in there but heres the manual , i know replacing fork oil is explained so youd think adjustment is http://www.betamotor.com/system/attachments/0000/2806/evo2t_2010_en.pdf (need adobe) just checked p71 Edited February 11, 2011 by scottraining Quote Link to comment Share on other sites More sharing options...
liviob Posted February 12, 2011 Report Share Posted February 12, 2011 If your stradling the bike as if to ride it the left fork leg is the compression damping leg and contains the spring. The adjuster on top of it controls spring preload. If you turn it clockwise you get more spring preload. The same as adjusting the spring preload collars on the rear shock. The fork leg on the right is the rebound damping leg. The adjuster on top of it controls rebound speed. Turning the adjuster clockwise gives you a slower rebound speed. Quote Link to comment Share on other sites More sharing options...
