dye29 Posted February 15, 2011 Report Share Posted February 15, 2011 hy all can anyone tell me alternative oils that can be used in engine and gear for montesa 4rt that are good Quote Link to comment Share on other sites More sharing options...
willrichardson Posted February 15, 2011 Report Share Posted February 15, 2011 hy all can anyone tell me alternative oils that can be used in engine and gear for montesa 4rt that are good Hi Been running mine on either silkolene Pro 4T or the castrol the Pidcocks suppply [can't remember the name]in the motor and it seems very happy. For the gearbox I use PJ1 two-stoke clutch tuner which, with CR125 "dimpled" metal plates [plenty of dealers sell these, got mine from BVM Moto for about Quote Link to comment Share on other sites More sharing options...
cyclist Posted February 15, 2011 Report Share Posted February 15, 2011 I have used the Silkolene Pro 4t in the engine & the ELF HTX in the gearbox. Bike has about 300 hours with no problems. Still doesn't use any oil. Clutch never dragging or sticky. Good stuff. Quote Link to comment Share on other sites More sharing options...
sir dabs alot Posted February 15, 2011 Report Share Posted February 15, 2011 I have used the Silkolene Pro 4t in the engine & the ELF HTX in the gearbox. Bike has about 300 hours with no problems. Still doesn't use any oil. Clutch never dragging or sticky. Good stuff. Where can you order these (Silkolene Pro 4t in the engine & the ELF HTX )from in the USA? Quote Link to comment Share on other sites More sharing options...
gii Posted February 15, 2011 Report Share Posted February 15, 2011 Mobil 1 works well in the motor and is available everywhere Elf HTX is the only oil that works properly in the gearbox / clutch. Other oils may be acceptable to their owners, but ELF HTX works best. Trouble is, it costs a fortune. On the plus side, it really doesn't need changing as often as people think. If you've had other oils in your gearbox,Silkolene, PJ1, ATF, Repsol,Motul, it'll take a couple of expensive changes with Elf HTX to get it all back to normal. In the USA, it's no coincidence that the Spares importer Overland Trail are also Elf agents. Suggest you contact Dennis Ziolkowski the proprieter, his email is info@overlandtrail.biz Quote Link to comment Share on other sites More sharing options...
dye29 Posted February 16, 2011 Author Report Share Posted February 16, 2011 the elf htx where do i buy this from any idea Quote Link to comment Share on other sites More sharing options...
cyclist Posted February 17, 2011 Report Share Posted February 17, 2011 (edited) Lewisport can supply the ELF & Silkolene oils are available in the US thru: http://lewisportusa.com/ Edited February 17, 2011 by cyclist Quote Link to comment Share on other sites More sharing options...
for artie Posted February 17, 2011 Report Share Posted February 17, 2011 ELF HTX is the cheapest to use becasue it lasts many times longer than any other oil. Another example of Cost vs Price. Quote Link to comment Share on other sites More sharing options...
dye29 Posted February 18, 2011 Author Report Share Posted February 18, 2011 ELF HTX is the cheapest to use becasue it lasts many times longer than any other oil. Another example of Cost vs Price. hy great just ordered a bottle of elf htx it was Quote Link to comment Share on other sites More sharing options...
