Can 200 be bored to 250?
mcman56
Even if it is you'd have to have the cylinder re-plated and properly size rings and piston. My guess is since they have different crankshafts the stroke is different the ports don't match. So now you'd be replacing the crankshaft as well. In the long run you could easily spend more money trying to make a 200 into a 250 then just buying a 250.
Summary:
No don't even try unless you own a machine shop and have a lot of time and money to spend.
Are the crankshafts really different? The specs I found are that the stroke is the same for 250 and 200 so what is different about the cranks? It looks like Beta took a different approach than Gas Gas by sleeving down a 250 rather than boring out a 125. Although mine is a 2008 so probably does not have an actual sleeve like mentioned in the post above.
Dan
