miketaco Posted February 17, 2011 Report Share Posted February 17, 2011 ok i bought a sherpa off ebay a while ago with the view to restore and ride, i've done 3 trials on it and want to get a few things done before the sammy miller rounds start. first off forks, im going to be riding the harder routes on this bike so with that in mind, can anyone recomend springs, oil and amount? also has anyone altered the fork angle? i've already got a mikuni vm26 in the garage and was hoping to use it but havnt got a clue what the jetting would be, anyone had any experience with these. Also thinking about skimming a little off the fly wheel to improve response, but worried i'll sacrefice grip. Going to lower and replace the footrests aswell. if anyone can help with any of these would be much apreciated, also if u have any other mods that are worth doing let me know. mike. Quote Link to comment Share on other sites More sharing options...
woody Posted February 17, 2011 Report Share Posted February 17, 2011 I have Magical fork spring kit in my 340 and it works very well with 10W oil about 180cc The Bultaco will cope with the Sammy Miller sections no problem, there is no need to modify the head angle. Agreed it improves steering but for that series it isn't necessary, there is nothing it won't steer around. You could always fit 360mm shocks which is what I did on an M49 I rode in the series a few years ago.If yours is the series 2 M91 they steer pretty well anyway. I haven't a clue about Mikuni jetting so can't help with that. I did fit an OKO to an M92 and it only needed minor change to main and pilot jets, it ran well straight out of the box. Skimming the flywheel is personal choice but again, there is nothing that a standard 250 motor can't cope with in the Miller series, it's a good strong torquey motor. My M49 had no problems. With taking weight off the flywheel I'd be more worried about losing low end plonk than anything else as the engine will stall easier meaning you'll be relying on the clutch more at slow speeds. The Bultos will lug right down to nothing with the standard weights. As a purely personal opinion, the best prep you could give the bike for that series is to ensure that the motor is set up right, carburation is correct and exhaust functioning properly. Good tyres. Get the front and rear suspension working correctly and get the riding position comfortable with bars and footrest position. If all that is correct it will make a marked difference on how the bike performs. Ride a few events with it and if you still feel it is necessary move onto the steering and flywheel mods, but I'm confident you'll find it isn't worth it. I've ridden both the M49 and KT250 in the Miller rounds hard route, they are similar handling bikes and both cope no problem. Quote Link to comment Share on other sites More sharing options...
miketaco Posted February 19, 2011 Author Report Share Posted February 19, 2011 Thanks for the advice woody, magicals are on there way. Quote Link to comment Share on other sites More sharing options...
miketaco Posted February 24, 2011 Author Report Share Posted February 24, 2011 anyone got any idea where to start with road registering? got some old v5's and mot's. Quote Link to comment Share on other sites More sharing options...
woody Posted February 24, 2011 Report Share Posted February 24, 2011 On 2/24/2011 at 6:39 PM, miketaco said: anyone got any idea where to start with road registering? got some old v5's and mot's. Don't follow you, if you have V5 it is road registered already Quote Link to comment Share on other sites More sharing options...
miketaco Posted February 24, 2011 Author Report Share Posted February 24, 2011 its the old style v5, in someone else's name and no tear off for new owner. Quote Link to comment Share on other sites More sharing options...
dabdab Posted February 24, 2011 Report Share Posted February 24, 2011 Re Magicals I understand that " Magicals " includes rear shocks and fork spring kits Does the range also include FORK VALVE KITS for the BETOR forks on Bultacos Finally, can someone provide me with the name and email of a UK based supplier Quote Link to comment Share on other sites More sharing options...
paulmac Posted February 24, 2011 Report Share Posted February 24, 2011 On 2/24/2011 at 9:01 PM, DabDab said: Re Magicals I understand that " Magicals " includes rear shocks and fork spring kits Does the range also include FORK VALVE KITS for the BETOR forks on Bultacos Finally, can someone provide me with the name and email of a UK based supplier Hi Mate Try this for the Magicals craig@themagicals.co.uk Paul Mac Quote Link to comment Share on other sites More sharing options...
triple_x Posted February 24, 2011 Report Share Posted February 24, 2011 Hi Bike settings are down to your personal choice. I have modified the yokes and had the head spindle rebored and sleeved so that the forks were parallel with the head. I have gone the Magical route and it transformed the bike, worth every penny! Mikuni. On my 80 series engine with ported barrel the jetting is Pilot 37, Needle Jet 182 N-8, Jet Needle 5F21, Throttle valve 2.5 and Main air Jet 2.0. raised the needle 1 notch from standard Bear in mind these setting work on my bike and suit me. Woody is right you don't need to play around with the steering for the SM Series, however i preferred my bike after the yokes were modified. See you in May at round 1. Regards Martin Quote Link to comment Share on other sites More sharing options...
woody Posted February 24, 2011 Report Share Posted February 24, 2011 On 2/24/2011 at 7:35 PM, miketaco said: its the old style v5, in someone else's name and no tear off for new owner. No problem, just apply for the V5 using Form V62 I think (from memory as the DVLA website is down at the moment) It will cost Quote Link to comment Share on other sites More sharing options...
woody Posted February 24, 2011 Report Share Posted February 24, 2011 On 2/24/2011 at 9:01 PM, DabDab said: Re Magicals I understand that " Magicals " includes rear shocks and fork spring kits Does the range also include FORK VALVE KITS for the BETOR forks on Bultacos Finally, can someone provide me with the name and email of a UK based supplier They are rear shocks, various types - single spring, multiple springs, fixed or adjustable damping. The front fork kits consist of a new progressive spring, internal adjustable spacer and the Magical fork cap with adjustable preload. There is no valving kit for the damping. Quote Link to comment Share on other sites More sharing options...
hightown Posted February 25, 2011 Report Share Posted February 25, 2011 On 2/24/2011 at 9:44 PM, Triple_X said: Hi Bike settings are down to your personal choice. I have modified the yokes and had the head spindle rebored and sleeved so that the forks were parallel with the head. I have gone the Magical route and it transformed the bike, worth every penny! Mikuni. On my 80 series engine with ported barrel the jetting is Pilot 37, Needle Jet 182 N-8, Jet Needle 5F21, Throttle valve 2.5 and Main air Jet 2.0. raised the needle 1 notch from standard Bear in mind these setting work on my bike and suit me. Woody is right you don't need to play around with the steering for the SM Series, however i preferred my bike after the yokes were modified. See you in May at round 1. Regards Martin Hello Martin I am very interested how you modified the top yokes,what do mean by the forks are parallel with the head. Thanking you in advance Hightown Quote Link to comment Share on other sites More sharing options...
