godzilla Posted February 17, 2011 Report Share Posted February 17, 2011 (edited) Do the holes in the 240 clutch plates (steel) need to be lined up and why are they there? Cheers Edited February 17, 2011 by godzilla Quote Link to comment Share on other sites More sharing options...
heavywrecker Posted February 17, 2011 Report Share Posted February 17, 2011 (edited) Do the holes in the 240 clutch plates (steel) need to be lined up and why are they there? Cheers Chap I guess the answer is no they don't need to line up,(as there is a solid friction plate between them) and the reason they are there is to make the clutch slip when you want it to, by allowing the oil to flow freely. However there may be a balance/ vibration issue if they aren't lined up? Cheers Bill Edited February 17, 2011 by heavywrecker Quote Link to comment Share on other sites More sharing options...
