scotty97 Posted April 7, 2011 Author Report Share Posted April 7, 2011 HAHA, i started a new job thats the thing, training courses away etc........... and i got a life thanks, and trials bikes is just a small part of it!!!!!!! Quote Link to comment Share on other sites More sharing options...
caddabs Posted April 7, 2011 Report Share Posted April 7, 2011 I'm by no means an expert, but i'd be tempted to pull the flywheel off and check your woodruff key (or keyway - see Copemech's suggestion). maybe before you do that - have you checked to see if you have a spark? Either way, i'd have a peek behind the flywheel. good luck Quote Link to comment Share on other sites More sharing options...
splatshop Posted April 7, 2011 Report Share Posted April 7, 2011 The rattly noise I can hear on your video is just the kick start ratchet clicking, they all do this and it isn't anything to worry about. As mentioned before check for a spark from the plug. If there is no spark try a new plug, disconnect your stop button, then check all your electrical connectors are tight and clean i.e. not corroded. If there is still no spark check your stator plate, have a look at the bottom of this page it goes through the readings. If you've got a spark, try cleaning your carburettor out as you might have got water or muck in the carburettor. Hope this helps Chris Quote Link to comment Share on other sites More sharing options...
scotty97 Posted April 7, 2011 Author Report Share Posted April 7, 2011 Cheers for your comments, il start working my way through the ideas tomorrow. yeah i may be hearing the rattle now cos theres no kick back at all and the bike use to kick back alot before this problem occurred Quote Link to comment Share on other sites More sharing options...
scotty97 Posted April 8, 2011 Author Report Share Posted April 8, 2011 Right new spark plug, cleaned carb got a spark Here's a better video of the noise Right got a flywheel pulled but struggling to get the nut off with out a rattle gun. Any ideas??? Quote Link to comment Share on other sites More sharing options...
scotty97 Posted April 8, 2011 Author Report Share Posted April 8, 2011 My oil cid:0CC9BE2A-D82C-496C-8618-A95B3A74D921/photo.JPG Quote Link to comment Share on other sites More sharing options...
cabby Posted April 8, 2011 Report Share Posted April 8, 2011 Just the other week I had a problem starting the bike (see my topic) went on't t'internet asking all the questions, and everyone giving their opinions. Seemed like I tried everything, carb cleaned a hunner times, new plug, getting a spark, off with kill switch etc etc. Eventually when I took it to our cheif trials mechanic he wiggled a few wires and it fired up, hasn't stopped working since. Now I'm not saying that's what your problem is, but get someone to have a wee poke round at all your wires, earths etc etc, check the wires coming out the Stator are in good condition...yada yada yada Quote Link to comment Share on other sites More sharing options...
scotty97 Posted April 8, 2011 Author Report Share Posted April 8, 2011 Just tried putting a photo of my oil up on here. It's only been in a few hours, just drained it and it looks like drinking chocolate?????? Quote Link to comment Share on other sites More sharing options...
scotty97 Posted April 8, 2011 Author Report Share Posted April 8, 2011 Video of my pil Sent from my iPhone Quote Link to comment Share on other sites More sharing options...
scotty97 Posted April 8, 2011 Author Report Share Posted April 8, 2011 Oil I meant!! Ha Quote Link to comment Share on other sites More sharing options...
copemech Posted April 9, 2011 Report Share Posted April 9, 2011 (edited) Right new spark plug, cleaned carb got a spark Here's a better video of the noise Right got a flywheel pulled but struggling to get the nut off with out a rattle gun. Any ideas??? I did not hear any unusual noises there. Oil has water or coolant in it, do you have plenty fluid in the radiator? Compression could be a bit low on this bike, as it seems to kick over fairly easily, yet hard to judge. Can you smell fuel on the plug after kicking over? There should be something coming in there, plug may get a bit wet. Still need to ck the wodruff key based upon you initial post, as you state you do have spark, yet possibly at the incorrect time for things to work. Make a flywheel holder or get a strap wrench if you do not have air tools, or find a mate that does. Edited April 9, 2011 by copemech Quote Link to comment Share on other sites More sharing options...
scotty97 Posted April 9, 2011 Author Report Share Posted April 9, 2011 Got some metal lastnight to make a holding tool, yeah compression does seem a bit less than usual but there's still some there. I know I had to top rad up a little bit last time I checked which thinking about it was just before I used it last. Il pull the cap off and check the level. If the levels low in the rad, where do I go from there???? Quote Link to comment Share on other sites More sharing options...
copemech Posted April 9, 2011 Report Share Posted April 9, 2011 Got some metal lastnight to make a holding tool, yeah compression does seem a bit less than usual but there's still some there. I know I had to top rad up a little bit last time I checked which thinking about it was just before I used it last. Il pull the cap off and check the level. If the levels low in the rad, where do I go from there???? If the level is low in the rad, then likely need the water pump seals, and your weep hole is blocked in the front of the case. Have you been riding deep water? Quote Link to comment Share on other sites More sharing options...
scotty97 Posted May 10, 2011 Author Report Share Posted May 10, 2011 Right then, I know it's been a while since I have been able to work on my bike (before people start leaving early comments!!) I have gone through most things and also had a mechanic looking at it too, this is what we found No spark- checked earths, plug, lead, checked wiring cos wires have been cut to remove light etc (why people do this baffles me as you can get a replacement harness for cheap) Removed flywheel- woodruff key is tidy, timing seems to be on factory setting ( will retard when bike is back up and running) Carb is clean Found that fuel pipe was creasing when tank was getting fitted back on bike, must be too long ( what length pipe do people fit between carb and tank Looked down cylinder and seems to be a build up of oil, I'm putting 65ml of oil in every 5 litres of super unleaded, does other people's look like this?? Mechanic reckons that it is not burning all the oil off??? Right then, suppose to be picking up a mates coil tonight to see if replacing that makes a difference, and also printed the test instructions to test the stator at same time. Mechanic reckons the lower compression was due to no fuel getting into cylinder, cos of creased pipe. Seems to be fine now??? Once I manage to get the bike sparking, then next on list is to find how that oil had water in it?? Any other ideas on electrical fault???? Quote Link to comment Share on other sites More sharing options...
chewy Posted May 10, 2011 Report Share Posted May 10, 2011 5 weeks later !!!! I'd be getting another job if youve been working every hour sinceyour previous posting.....there is such a thing as life, may i suggest you go get one. Always "flowering it up" with a kind word , the poor chap obviously hasn't a clue , doesn't want to pull the flywheel off, maybe hasn't checked the kill switch or if it's sparking..he'll get there with time! Quote Link to comment Share on other sites More sharing options...
