grib Posted February 28, 2011 Report Share Posted February 28, 2011 ....i just got a case today, when it turned up it was from a 300 (I was gutted) .... According to this later 240s were fitted with the same cover as the 300. I have two 240s; one with an engine number below 8500 and the early casing, and one with an engine number above 8500 and the later casing, so it seems to be true and your cover isn't actually wrong. Quote Link to comment Share on other sites More sharing options...
lee harris Posted March 1, 2011 Author Report Share Posted March 1, 2011 Lee, from your comment above about having a 241 motor - will a 240 cover fit on any of the later crankcases or is the hole spacing different. I know the later flywheels are bigger (but I have a plan for that). I am sure they will fit and the spacing is the same...and I have the same plan as you. Ducati flywheel from a 303 or 305, turned down to fit inside and then a huge flywheel weight....already on the go L Quote Link to comment Share on other sites More sharing options...
grib Posted March 1, 2011 Report Share Posted March 1, 2011 I am sure they will fit and the spacing is the same...and I have the same plan as you. Ducati flywheel from a 303 or 305, turned down to fit inside and then a huge flywheel weight....already on the go L Same plan - I am going to use a 245 motor with the flywheel machined down and a leaded bronze weight fitted. With the 300/later 240 cover fitted the raised pattern on the clutch & ignition covers will even match Quote Link to comment Share on other sites More sharing options...
lee harris Posted March 1, 2011 Author Report Share Posted March 1, 2011 Same plan - I am going to use a 245 motor with the flywheel machined down and a leaded bronze weight fitted. With the 300/later 240 cover fitted the raised pattern on the clutch & ignition covers will even match i will keep yer posted on the cover. do the same on the flywheel please. there are loads of ducati sxstems out there and motoplatts or ducatis for 300s are few and far betweenb Quote Link to comment Share on other sites More sharing options...
spud1968 Posted March 1, 2011 Report Share Posted March 1, 2011 Just to be different i've raised my 243 donor engine in my 240 chassis. Its taken two guys working for 3hours cutting and welding. The exhaust is modified so are the front engine brackets. The carb lines up better with the standard air box rubber, better than standard and i can remove the exhaust without having to remove the cylinder head. These ideas are all from the 243 setup, which is an excellent donor bike. Now what i want to know is what is Gerd riding at Exmoor Lee? Quote Link to comment Share on other sites More sharing options...
lee harris Posted March 2, 2011 Author Report Share Posted March 2, 2011 Just to be different i've raised my 243 donor engine in my 240 chassis. Its taken two guys working for 3hours cutting and welding. The exhaust is modified so are the front engine brackets. The carb lines up better with the standard air box rubber, better than standard and i can remove the exhaust without having to remove the cylinder head. These ideas are all from the 243 setup, which is an excellent donor bike. Now what i want to know is what is Gerd riding at Exmoor Lee? MAYBE THIS ONE http://www.korallin.us/wbb2/attachment.php?attachmentid=9958 OR THIS http://www.korallin.us/wbb2/attachment.php?attachmentid=9988 POSSIBLY THIS http://www.korallin.us/wbb2/attachment.php?attachmentid=10219 but I think his favorite is a std 340....I dont have piccies... like mine but finished. Interesting who is coming. twice German champ ortwinn sann.....got 67 marks on start route last year, 3 times runner up gerd, got 88 on start route and the new kid on the block...arnold kopf. wonn this year the german championship...has never been to the uk. i have my makeup case packed for the gentlemanns route, maybe erwin also. post some puiccies of your 240 now L Quote Link to comment Share on other sites More sharing options...
spud1968 Posted March 2, 2011 Report Share Posted March 2, 2011 (edited) Its good to read the pro German riders will be competing at Exmoor and Gerd is riding an all new Fantic special called a 340. Gerd had a better result than me the other year. This is definately not a big deal for me i am 10 years older than Gerd and his 240 was far more advanced than mine. I'm not the kind of person that goes on about this as you know, we all ride for fun not to beat each other and I wasn't well the other year. I think I had a problem with me leg and my 240 wasn't 100%. I'm really not that interested in what Gerd's riding you know I was just a little surprised in a good way that he's riding a better bike for this years even. The 340 bikes spec and tyres are normal I suspect do you know what they are? Not to worry if you don't. Perhaps a few drinks the night before, Gerd likes a good drink this should relax him before the first days ride. Exmoor is only a fun trial and i'm still putting my bike together. Those links go to a German website that asks for registration. Edited March 2, 2011 by spud1968 Quote Link to comment Share on other sites More sharing options...
lee harris Posted March 3, 2011 Author Report Share Posted March 3, 2011 Its good to read the pro German riders will be competing at Exmoor and Gerd is riding an all new Fantic special called a 340. Gerd had a better result than me the other year. This is definately not a big deal for me i am 10 years older than Gerd and his 240 was far more advanced than mine. I'm not the kind of person that goes on about this as you know, we all ride for fun not to beat each other and I wasn't well the other year. I think I had a problem with me leg and my 240 wasn't 100%. I'm really not that interested in what Gerd's riding you know I was just a little surprised in a good way that he's riding a better bike for this years even. The 340 bikes spec and tyres are normal I suspect do you know what they are? Not to worry if you don't. Perhaps a few drinks the night before, Gerd likes a good drink this should relax him before the first days ride. Exmoor is only a fun trial and i'm still putting my bike together. Those links go to a German website that asks for registration. not exactly "pro" caliber but the best riding ts trials. Gerd rode twice now and thinks hes got the slippery rocks sussed. Ortwin still beat him first time out. Arnold, new kid will pro beat both... Arnold 240 is not trick, its a shed. I would be embarresed to ride it and yet he still wins. Ortler has a std 300 with keihin carby. Gerd and I have modded 240 frames with 300 motors. I run a keihin, gerd a mikuni. As you said, fun is what we want! Gettin back to the thread, post some piccies cliff, I wanna see how much you lifted the front and what cuts and welds were made to the exhaust speak soon PS. I havent done yer kickers yet.. Quote Link to comment Share on other sites More sharing options...
spud1968 Posted March 5, 2011 Report Share Posted March 5, 2011 So Arnold is the man, obviously very talented so he can ride the sections first to keep things fair. Are you riding Star Route this year? I'd like to post a photo or two but unfortunately the bike is in bits and this weekend i'm racing an enduro, so my focus is prepping the enduro bike. Next Saturday i'll have some time spare thou. Would you happen to know the manufacturers piston to bore clearance tolerance on a 212cc engine i've three pistons but not sure which one to fit? The engine was raising between 12-14mm. The clearance allows a 16th of an inch rubber spacer to sit between the bottom of the magneto casing and frame. The engine raise was more of a case of lifting the engine until the case cleared insert the rubber spacer and then mark that position for modifying the standard front engine brackets because of the tilt. If you bring along to Exmoor a standard set of 240 front engine brackets i'll remove my modified brackets for you to measure. The exhaust is a little more complex with two cuts one permanant the other for positioning. Bring your camera for that and some spanners if your really interested. Call me or facebook me the accomadation for what your arranging. Once the engine is done its time to move onto the suspension and brakes, so lots to do. Quote Link to comment Share on other sites More sharing options...
grib Posted August 1, 2011 Report Share Posted August 1, 2011 i will keep yer posted on the cover. do the same on the flywheel please. there are loads of ducati sxstems out there and motoplatts or ducatis for 300s are few and far betweenb It's taken me a while to get round to doing this but here it is: Leaded bronze would have been eye wateringly expensive as it turns out, so I made the weight from steel instead. The modified flywheel with the new weight has the same moment of inertia as the 245 one with the big weight fitted (the other flywheel in the picture). How have you got on with your flywheel covers Lee? Quote Link to comment Share on other sites More sharing options...
lee harris Posted August 3, 2011 Author Report Share Posted August 3, 2011 Its been on for 11 trials now. No cracks and no leaks. I have scrapped a few rocks as you do and it shows battle scars as the alu one without cracking. I am chuffed. Pm me fir more info Lee Quote Link to comment Share on other sites More sharing options...
grib Posted August 3, 2011 Report Share Posted August 3, 2011 Lee, tried sending you a PM but it says you can't receive any new messages. Are you going to be making some more covers? Quote Link to comment Share on other sites More sharing options...
ducman Posted August 4, 2011 Report Share Posted August 4, 2011 Lee, tried sending you a PM but it says you can't receive any new messages. Are you going to be making some more covers? If he got some in stock i can bring it to the Manx 2 Day Classic. Chrs:Mike Quote Link to comment Share on other sites More sharing options...
