evo ohlins shock
spudsdad
what are the diferances between the gold and silver ohlins that are available [apart from colour]
You should try the TRP , i am very happy with this shock and you can adjust the rebound with out remouving the fender.
ben do they mount the same way up as a std shock eg: rebound adjuster at top
Hi,
I have mounted mine the opposite way round with the rubber bump stop at the bottom, (I saw a picture of it on that way on a website)But I have seen a few lads who have mounted them the same way as the original shock with the adjustment rings at the bottom. It probably works the same which ever way you mount it.
Edited by BenBeta23
  • 4 months later...
