TL125 compatible triple clamp
skeptic
The triple clamp (upper clamp) on my 1974 TL125 is broken. Where the bolt tightens, it fractured and separated on the side opposite the bolt. I don't think welding would work. What other makes/models would be compatible with the stock upper clamp/bridge?
  • Dislike 1
Anyone?
  • Dislike 1
  • 2 months later...
I had the same thing happen on my '74 TL-125, and it was able to be welded. It took a bit of finish grinding to get it back to original dimensions, but the weld has been holding for about a year now. Take it to someone experienced in aluminum welding and it should not be a problem. --Cheers.
