fuel mix and which 2 stroke oil ?
myzeneye
hi guys....
just bought a sherco 250 (2003)....can any one advise on the best two stroke oil i should use and what mix will be best for my machine....which brand and should i use fully or semi synthetic ?
also, are the premium/high octane fuels better to use then the normal bog standard petty ?
thanks folks... :icon_salut:
  On 3/4/2011 at 10:24 PM, t-shock 250 said:
Most people run a ratio of 80:1.
This is 62ml of oil to 5 litres of petrol.
Use only full synthetic oil.
This is true. Add the fact if you are just putting about all the time and no roads or continued high revving or hard running, you can go down to 100:1 or 50ml per 5L.
This helps prevent excess buildup in the muff and such, as well as being a bit more envionmently friendly. :thumbup:
