jsp Posted March 5, 2011 Report Share Posted March 5, 2011 just taken the flywheel cover off my 2010 evo 4t and there is water in there, i am going to clean it all up and fit a new gasket and silicone up the cables going in. i am ok the spray wd40 in there before i refit the cover ? jsp Quote Link to comment Share on other sites More sharing options...
betarick Posted March 5, 2011 Report Share Posted March 5, 2011 I would blow it out with a airline first then spray wd40 in! Quote Link to comment Share on other sites More sharing options...
andyjohnson Posted March 9, 2011 Report Share Posted March 9, 2011 take off the cover after every ride and blow out with an airline , youll find lots of water in there after you have power washed it, when i got my first beta i tried allsorts to stop it getting in but you cant! in fact ive drilled the bottom of the casing to let out most of it before i take it off to clean it out ! then spray wd in and put he casing back on and your done! (till nxt time) andy Quote Link to comment Share on other sites More sharing options...
jsp Posted March 9, 2011 Author Report Share Posted March 9, 2011 mines a 4 stroke you cant take the casing off after every ride as you would need to replace the gasket every time jsp Quote Link to comment Share on other sites More sharing options...
