alvin123 Posted March 6, 2011 Report Share Posted March 6, 2011 Just fitted a new rear shock to my gas gas 200. I need to raise the ride height, do I wind the spring lock nuts up to show more thread below the spring or lower the nuts. Currently the swing ARM is very close to horizontal. Thanks Quote Link to comment Share on other sites More sharing options...
richt Posted March 6, 2011 Report Share Posted March 6, 2011 You need to wind the locknuts clockwise to show more thread and this will compress the spring, Sounds like you may have to do a couple of full turns, then see how much it has lifted the bike. Hope this helps. Quote Link to comment Share on other sites More sharing options...
gronno Posted March 6, 2011 Report Share Posted March 6, 2011 I keep meaning to have a look at this on mine. How much laden sag should I be aiming for when measured at the axle? Quote Link to comment Share on other sites More sharing options...
richt Posted March 6, 2011 Report Share Posted March 6, 2011 I keep meaning to have a look at this on mine. How much laden sag should I be aiming for when measured at the axle? I reckon the general rule is about 1/3 of the available suspension travel, This could vary between different bike manufactures. But personal preference is also a rule. Quote Link to comment Share on other sites More sharing options...
gronno Posted March 7, 2011 Report Share Posted March 7, 2011 I reckon the general rule is about 1/3 of the available suspension travel, This could vary between different bike manufactures. But personal preference is also a rule. Ah,so, 164mm rear travel = 54mm sounds reasonable, too the tape measure! Quote Link to comment Share on other sites More sharing options...
copemech Posted March 8, 2011 Report Share Posted March 8, 2011 Getting the bike to settle a bit under it's own weight(static sag)of about 20mm would be a good start. Yoiu can easily judge this by motion of lifting the mudguard a bit with the bike standing verticle. Quote Link to comment Share on other sites More sharing options...
