theotherone Posted March 12, 2011 Report Share Posted March 12, 2011 Hi guys. Picking up an '04 Rev 3 270 at the weekend. Would appreciate any advice you can give me about best fuel mix, oil type and anything else you care to offer up as advice on the Rev 3. Owned GasGas and Sherco before, so not a total novice to trials, but to Beta I am!!!!!! Best places for spares would be great too!!! Quote Link to comment Share on other sites More sharing options...
rev3 Posted March 12, 2011 Report Share Posted March 12, 2011 I use semi synthetic oil and have used every different type going on all my bikes and cannot tell the difference, except this one smells of strawberry. I use 15ml per litre, never had a problem and runs crisp anytime of the year, I would say, if it has a Champion plug, bin and put in an NGK. Air filter gets dirty and i clean it after every trial. Quote Link to comment Share on other sites More sharing options...
theotherone Posted March 12, 2011 Author Report Share Posted March 12, 2011 Thanks for the tip about the spark plug. I'll check it when I get it. Quote Link to comment Share on other sites More sharing options...
hughes73 Posted March 12, 2011 Report Share Posted March 12, 2011 Check the water pump for corrosion and I remove flywheel cover after every ride and spray with WD40. Quote Link to comment Share on other sites More sharing options...
steam Posted March 12, 2011 Report Share Posted March 12, 2011 Check the water pump for corrosion and I remove flywheel cover after every ride and spray with WD40. Do you remove the flywheel as well before you spray WD40 Quote Link to comment Share on other sites More sharing options...
