jools Posted March 16, 2011 Report Share Posted March 16, 2011 Hi there! I have a few questions regarding the TLM 260R; 1) Could someone please advise what Fuel/oil pre mix ratio should be? 2) The recommended gear-box oil and the correct volume? 3) The correct spark plug type? Answers to these would be a huge help! Thanks very much. Quote Link to comment Share on other sites More sharing options...
sam95 Posted March 16, 2011 Report Share Posted March 16, 2011 (edited) i run my tlm at 50:1 and i think the gear box oil is sae 10-30 w motor oil i use morris i belive it to be 0.5L if just topping up and 0.6L if doing a engine rebuild but dont qout me on that it should say by the hole were u put the oil in. sorry but i havent got any idea what spakr plug it is as mine is a different cc to yours (200) hope this helps and any one can correct me if im wrong Edited March 16, 2011 by sam95 Quote Link to comment Share on other sites More sharing options...
sam95 Posted March 16, 2011 Report Share Posted March 16, 2011 oh and here and i know its for a 240 tlm but some thinks are inter change able and it has similer values Quote Link to comment Share on other sites More sharing options...
jools Posted March 18, 2011 Author Report Share Posted March 18, 2011 Thanks for your reply! So 50:1 I make that 100ml oil to 5 litres of fuel (I'm no good at ratios!). Sounds about right. No problem about the spark plug I'll make some calls. Thanks for the link aswell!! Quote Link to comment Share on other sites More sharing options...
