New bike
adam1
Basically its the same engine as your Rev3 so the same oil in the gearbox. The current beta gearbox is the same as the 94 Techno all but a few tweaks.
You will have rear linkage to strip n check i would assume n wheel bearings to check n brake pads.
Should be bullet proof as it was the last model so should be the best of technos all be it old.
Cheers for that, just got back from picking it up. As you said it is 12 years old but not in bad nic. will check all the obvious tomoz
cheers
Adam
  • 4 weeks later...
