Montesa 314
robsmith
Good engine in those bikes.
Ignition timing can be adjusted by fitting a different chip under the seat, blue is std grey is advanced from memory. Not sure if you can adjust the timing at the stator as I never took the flywheel off mine.
I used fuel mix of 50 to 1 but oil is a bit better now so you may get away with 60 or 70 to 1.
enjoy
