markieboi Posted March 22, 2011 Report Share Posted March 22, 2011 Hi, Have a Rev 3 2001, the kick start is loose and just flops around. Is there a spring missing? As I removed the kick start lever using the smaller bolt and there seemed to no mechanics to keep the lever in place when not in operation. I'm new to beta coming from sherco, so any advice is appreciated. Quote Link to comment Share on other sites More sharing options...
shercojay Posted March 22, 2011 Report Share Posted March 22, 2011 Hi, Have a Rev 3 2001, the kick start is loose and just flops around. Is there a spring missing? As I removed the kick start lever using the smaller bolt and there seemed to no mechanics to keep the lever in place when not in operation. I'm new to beta coming from sherco, so any advice is appreciated. sell it and get another sherco !!!!! Quote Link to comment Share on other sites More sharing options...
markieboi Posted March 24, 2011 Author Report Share Posted March 24, 2011 Wow, thanks for all the help! Quote Link to comment Share on other sites More sharing options...
adam1 Posted March 24, 2011 Report Share Posted March 24, 2011 Hi mate just seen this post, the rev 3 is a great bike IMO but the kick starts do flop around a little mine does and it's a 07, but once it's back in position up against the frame it shouldn't fall back down but it may rattle around a little Adam Quote Link to comment Share on other sites More sharing options...
betabonkers Posted March 24, 2011 Report Share Posted March 24, 2011 there should be a little ball bearing in there. Quote Link to comment Share on other sites More sharing options...
markieboi Posted March 25, 2011 Author Report Share Posted March 25, 2011 Ah right thanks, mine doesn't just rattle around it actually flops out as if your going to kick it over. Does the BB just float free inside the kick start then? ie, to give the kick start some resistance and stop the freedom of movement. Quote Link to comment Share on other sites More sharing options...
jsp Posted March 25, 2011 Report Share Posted March 25, 2011 the ball bearing is held in by a spring and a grub screw jsp Quote Link to comment Share on other sites More sharing options...
ioan_vapi Posted April 14, 2011 Report Share Posted April 14, 2011 the ball bearing is held in by a spring and a grub screw jsp Something similar happened to me and I found a loosen screw on top of the kickstart case under the middle exhaust pipe. I have fixed it screwing it in back. Quote Link to comment Share on other sites More sharing options...
markieboi Posted April 14, 2011 Author Report Share Posted April 14, 2011 Something similar happened to me and I found a loosen screw on top of the kickstart case under the middle exhaust pipe. I have fixed it screwing it in back. Hi, When I got it all taken off it was missing the 10mm BB. Thankfully an easy fix Quote Link to comment Share on other sites More sharing options...
