GasGas Kickstart Shaft Conversion
rustybay
Hi There
Can anybody help. I have broken my kickstart shaft on my JT35 and now need to convert it from a 16 mm to a 18 mm. Has anyone done this conversion - if so all information would be much appreciated.
Information required:
1. The dia of the hole I need to enlarge in the outer casing to accept the new seal and bush
2. The item numbers for the new seal and the new shaft bush
Finally will any kickstart arm now fit the 18 mm spline shaft.
Thank in advance
Wayne
  • 1 month later...
Sorry I can't help you with the question, but I just broke my kickstart lever on my 16mm shaft and am in need of the clamp and lever. When I pulled the clamp the allen bolt on top busted off, so I drilled it out and when I went to retap it the tap broke off inside. The tap is to hard to drill into and now I'm stuck. Is your old one available if you still have it? Are you in the US?
Thanks ( I hope )
Brandon
