2010 fuel tap?
shercojay
Anybody shine some light on this, took the carb off today to clean it, however when i pulled the fuel pipe off the pump the fuel just kept coming out.
pls dont tell me I need to drain the every time I do maintance on the bike?????
as always thanks in advance
Just a thought, could you not find a bolt of the right size to bung up the pipe to stop it leaking? I did this on a unused vacuum hose on my supermoto once and it worked a treat.
I thought about this myself, but by the time the bolts in, there's petrol all over the place
You could put the front wheel up on the work bench (Workmate vice is best)...assuming it would leak out of the fuel cap like that... But I really think the extra in-line tap is your best option.
Best of balance.
Neo
