shercojay Posted March 26, 2011 Report Share Posted March 26, 2011 Anybody shine some light on this, took the carb off today to clean it, however when i pulled the fuel pipe off the pump the fuel just kept coming out. pls dont tell me I need to drain the every time I do maintance on the bike????? as always thanks in advance Quote Link to comment Share on other sites More sharing options...
chewy Posted March 26, 2011 Report Share Posted March 26, 2011 Why not put it up (the end) higher than the the tak or fuel level.. works for me Quote Link to comment Share on other sites More sharing options...
shercojay Posted March 26, 2011 Author Report Share Posted March 26, 2011 good idea but is there a easyer way?? Quote Link to comment Share on other sites More sharing options...
baldilocks Posted March 27, 2011 Report Share Posted March 27, 2011 yes I've added an in line petrol tap to mine so I can turn the petrol off when I clean the carb. cost a Quote Link to comment Share on other sites More sharing options...
shercojay Posted March 27, 2011 Author Report Share Posted March 27, 2011 yes I've added an in line petrol tap to mine so I can turn the petrol off when I clean the carb. cost a Quote Link to comment Share on other sites More sharing options...
johnnydudeuk Posted March 27, 2011 Report Share Posted March 27, 2011 sorted you dont have a ebay link for it do you Just a thought, could you not find a bolt of the right size to bung up the pipe to stop it leaking? I did this on a unused vacuum hose on my supermoto once and it worked a treat. Quote Link to comment Share on other sites More sharing options...
shercojay Posted March 27, 2011 Author Report Share Posted March 27, 2011 Just a thought, could you not find a bolt of the right size to bung up the pipe to stop it leaking? I did this on a unused vacuum hose on my supermoto once and it worked a treat. I thought about this myself, but by the time the bolts in, there's petrol all over the place Quote Link to comment Share on other sites More sharing options...
neo Posted March 28, 2011 Report Share Posted March 28, 2011 You could put the front wheel up on the work bench (Workmate vice is best)...assuming it would leak out of the fuel cap like that... But I really think the extra in-line tap is your best option. Best of balance. Neo Quote Link to comment Share on other sites More sharing options...
tricky dicky Posted March 28, 2011 Report Share Posted March 28, 2011 Dead easy. When you pull the pipe off the carb squeeze the pipe and it will obviously stop the fuel coming out. I just push a philips screwdriver into the end of the pipe and job done. Quote Link to comment Share on other sites More sharing options...
cabby Posted March 28, 2011 Report Share Posted March 28, 2011 sorted you dont have a ebay link for it do you http://shop.ebay.co.uk/?_from=R40&_trksid=p5197.m570.l1313&_nkw=in+line+fuel+tap&_sacat=See-All-Categories Quote Link to comment Share on other sites More sharing options...
