rollo Posted March 29, 2011 Report Share Posted March 29, 2011 Hi all, i've got a strange thing; The rear brake on my beta rev4t 2008 brakes a lot better when the system gets wet. For as i can tell the disc is not damaged, the pad are not worn out, and there is no air in the system. Does anybody have a clue what causes the bad braking when the system is dry? Quote Link to comment Share on other sites More sharing options...
jimmyl Posted March 29, 2011 Report Share Posted March 29, 2011 Possible pads/disc contaminated or glazed - water helps clean surface Quote Link to comment Share on other sites More sharing options...
telecat Posted March 29, 2011 Report Share Posted March 29, 2011 Remove the Pads and Gently rough up the surface with a fine sandpaper. I'd check you don't have a leaking rear caliper. Quote Link to comment Share on other sites More sharing options...
paul w Posted March 29, 2011 Report Share Posted March 29, 2011 are you sure its just not the tyre gripping better in the dry? Quote Link to comment Share on other sites More sharing options...
rollo Posted March 30, 2011 Author Report Share Posted March 30, 2011 I'll try to roughen up the pads, lets see if that helps. The Calipers are not leaking, i'd checked that before. It's also not the tyre grip, in dry conditions the braking is bad. When i spray on a little water on the disc an caliper the brake works fine. Thanks for the suggestions. Quote Link to comment Share on other sites More sharing options...
