pillar Posted March 30, 2011 Report Share Posted March 30, 2011 So I had my bike fully freshened up a couple months ago. I went to use it for the first time last weekend and both fork seals were leaking!! ;-( All we did was fresh oil in the forks for that portion of the tune up. The fork seals were not leaking before! What could cause this? I removed the dust covers and cleaned that area out. I also took a thin firm paper and ran it around the fork seal to get any crap out of there. It worked for a bit and then started leaking again. I usually keep the bike on a stand with the wheels in the air when not riding it. I took it off the stand now so its just resting on it's own weight now. Any suggestions?? Quote Link to comment Share on other sites More sharing options...
spenser Posted March 30, 2011 Report Share Posted March 30, 2011 (edited) I would suggest that if you didn't use the height measurement way of adding fluid, you may want to try that; you may have added too much fluid. Who did the work Chad? Spencer Edited March 30, 2011 by Spenser Quote Link to comment Share on other sites More sharing options...
pillar Posted April 1, 2011 Author Report Share Posted April 1, 2011 I would suggest that if you didn't use the height measurement way of adding fluid, you may want to try that; you may have added too much fluid. Who did the work Chad? Spencer Hey Spensor, Ted B did the work. He just put a new fork seal in his, now he has a slow leak!! What is he doing wrong?? Now I'm paying for it! lol Thanks Quote Link to comment Share on other sites More sharing options...
spenser Posted April 3, 2011 Report Share Posted April 3, 2011 Hey Spensor, Ted B did the work. He just put a new fork seal in his, now he has a slow leak!! What is he doing wrong?? Now I'm paying for it! lol Thanks I will give Ted a call to see if anything stands out. I would not really expect that Ted would have a problem with the seals, but I have found that some people have not given the fluid level quite the attention that it needs. Spencer Quote Link to comment Share on other sites More sharing options...
pillar Posted April 4, 2011 Author Report Share Posted April 4, 2011 I will give Ted a call to see if anything stands out. I would not really expect that Ted would have a problem with the seals, but I have found that some people have not given the fluid level quite the attention that it needs. Spencer Ok thanks. Ya, Ted knows these bikes pretty gd. Might be something minor. If there was a bit too much oil added, that would cause this to right? Quote Link to comment Share on other sites More sharing options...
pillar Posted April 8, 2011 Author Report Share Posted April 8, 2011 Hey Spencer, any work from Ted? Thanks. Did you get my email I sent you on here? Quote Link to comment Share on other sites More sharing options...
