whitehawkpete Posted April 2, 2011 Report Share Posted April 2, 2011 Hi trying to find a brand new tlr 200 airbox , but can only find a Californian model box , does any one know what the difference is between the two boxes. Iknow it must have extra emissions stuff, but I don't know how different the case,s are , can anyone help ??. Quote Link to comment Share on other sites More sharing options...
mcman56 Posted April 2, 2011 Report Share Posted April 2, 2011 I have what I believe to be a CA TLR200 and can make a guess at what might be different. It had a rubber snorkel type thing that snapped into the top opening. I suspect it was a silencer and just pops out. There is a 1/2 hole in the top which took some type of smog or breather hose. I don't remember what it was but it could also be easily plugged. The crankcase breather hose has a path into the box and plugs into the metal holder for the foam filter. The bottom of the air box also has a metal heat shield that sits over top of the mid muffler. I don't know if a standard TLR has the mid muffler. A site like bikebandit.com should have a part diagram so you could see what extras are there. Quote Link to comment Share on other sites More sharing options...
