lewisjambo123 Posted April 4, 2011 Report Share Posted April 4, 2011 Ive got a ty250 mono and it is leaking gearbox oil threw the clutch cover, I have replaced the gasket but the thread in the crank case for one of the lower clutch cover blolts is stripped, is there anything I could do to fix this? Cheers Lewis Quote Link to comment Share on other sites More sharing options...
handsome_al Posted April 4, 2011 Report Share Posted April 4, 2011 Hi Lewis. What you need is a 'helicoil'. You'll also need the appropriate helicoil tap and helicoil insertion tool. I'm assuming you don't know what one is. If you do, then sorry. A helicoil looks very much like a compression spring only it is threaded to accept the original screw. The stripped hole is tapped out (larger) with the helicoil tap; the helicoil insert is then placed in the tool, which then inserts it into the newly tapped hole. Once in place, you wind the tool backward to snap-off the insertion tag and then continue to wind the tool come all the way back out. Job done. To be honest, unless you have lots of stripped threads - or intend stripping more! - it may be cheaper to find a local engineering firm to do it for you. It'll take them all of 10minutes to do. Quote Link to comment Share on other sites More sharing options...
lewisjambo123 Posted April 4, 2011 Author Report Share Posted April 4, 2011 Thanks for your info, I wasn't sure if there would be enough room for the helicoil on the crank case as its quite thin, so I will see if some were local can do it. Cheers Quote Link to comment Share on other sites More sharing options...
handsome_al Posted April 4, 2011 Report Share Posted April 4, 2011 There IS another, more complicated way but I don't think it will be strong enough. Used metal putty to fill the hole completely; place the casing back on and use a drill (same size as the clearance hole in the case) to 'spot' the center again. The drill out with tapping drill (5.2mm if M6 thread) and re-tap the hole. It might work but I don't hold much hope in in being strong. Quote Link to comment Share on other sites More sharing options...
