brakes again!
shercojay
Ok was replacing my front pads and everything was going well, then start to bleed the system and the pistons wont move!!!
No matter which way I try it they wont come out, so tried to split the case and low and behold the head of the bolt is chewed to bits
Anyone got any ideas on how to free them,I was think compressed air but wont this damage the seals???
as always thanks guys
Edited by ShercoJay
  On 4/8/2011 at 2:59 AM, copemech said:
I just do not understand this Isuppose. Why would you want to bleed the brakes while replacing pads? And on a '10 model?
I always change my brake fluid when I replace my pads cope!! Abit geeky I know but thats my maintance
After a bit of messing about I think its the master cylinder because there's no pressure there
Oh, I see! Do you have a syringe, or anything else that you might use to fix this and use for other forms of self induced mutilation? :rolleyes:
Get the calliper off and in a good vice. Cut a slot down the middle of the head of the bolt (not too deep) with metal cutting blade on and angle grinder. Then use an impact driver (fat screwdriver bit) to to undo the bolt. Then take the calliper halves to a car brake repair place and they'll pull the pistons out with ease.
But I too can't understand why you'd need to do all this on such a new bike :blink:
Best of balance.
Neo
Edited by Neo
  On 4/9/2011 at 10:35 AM, ShercoJay said:
all sorted !!!
Sorry Jay but we can't let you off that lightly ;) .... How did you sort it?.... a 10 page write up will do nicely :lol:
Best of balance.
Neo
  On 4/9/2011 at 6:42 PM, ShercoJay said:
Yep, thing is all the dirt and mud can easy get inside, its only a rubber boot that stops it
Correct me if I'm wrong but that's the same AJP MC that's been used on many Trials bikes for many years now. Most of which give little trouble. And that rubber boot you mentioned never lets anything go past it .....unless it was defective in some way or the two screws on the cap were loose ??
Best of balance.
Neo
Well that's what am putting it down to, most of the time if you look the boot isn't really giving a seal!
Only other thing I can think of is when I back bleeded it, this has pushed the seals out ??? But for 7 quid am not going to complain
