charlie prescott Posted April 15, 2011 Report Share Posted April 15, 2011 Hi Guy's. I have this week taken two road bikes for MOT. And both of them, have had to have bigger rear number-plates fitted. So does this mean that all motorcycles that are road registered, need this size of plate? I was told it is three points and a Quote Link to comment Share on other sites More sharing options...
hrc1 Posted April 15, 2011 Report Share Posted April 15, 2011 Yes.....and plate of "correct material" with supplier's post code!! Quote Link to comment Share on other sites More sharing options...
bigbrowndog Posted April 15, 2011 Report Share Posted April 15, 2011 Its a nightmare. I just took my old Lambretta for MOT and had to take the slightly smaller, 6 1/4 inch number plate off for an hour and put a full size one on. Quote Link to comment Share on other sites More sharing options...
cabby Posted April 15, 2011 Report Share Posted April 15, 2011 No points, and unless things have changed its a Quote Link to comment Share on other sites More sharing options...
pete_scorpa3 Posted April 15, 2011 Report Share Posted April 15, 2011 Loads of bikes would fail if the Police got out their tape measures, but the important thing is to be sensible. If they can clearly see the numbers and the plate is yellow and upright (ish) then at least you've given yourself a fighting chance of getting away with it. Quote Link to comment Share on other sites More sharing options...
bulltaco Posted April 15, 2011 Report Share Posted April 15, 2011 Here are the DVLA approved sizes, you can work out the size of plate you should have. This refers to bikes registered after 2001, I think. Character height 64 mm Character width (except the figure 1 or letter I) 44 mm Character stroke 10 mm Space between characters 10 mm Space between groups 30 mm Top, bottom and side margins (minimum) 11 mm Space between vertical lines 13 mm Quote Link to comment Share on other sites More sharing options...
beatabeta Posted April 15, 2011 Report Share Posted April 15, 2011 Best way around it 'if' you're that way inclined... Get an official, full size numberplate , attach it correctly to your bike, when you have the correct holes etc in yourmudguard remove it the numberplate and snap the numberplate at the top. Then, whenever you are doing a road trial attach the bracket with the broken 'bit' of the numberplate on and if you do get pulled over at a trial you have a 'bit' of the regulation full size plate and bracket attached but had an unfortunate 'crash' in a section. You can show them the snapped bit in your pocket, bumbag, camelback etc etc. This is then all OK and above board, nothing canbe done as you will get a new plate ASAP on Monday morning when the shops open. Quote Link to comment Share on other sites More sharing options...
pete_scorpa3 Posted April 15, 2011 Report Share Posted April 15, 2011 Best way around it 'if' you're that way inclined... Get an official, full size numberplate , attach it correctly to your bike, when you have the correct holes etc in yourmudguard remove it the numberplate and snap the numberplate at the top. Then, whenever you are doing a road trial attach the bracket with the broken 'bit' of the numberplate on and if you do get pulled over at a trial you have a 'bit' of the regulation full size plate and bracket attached but had an unfortunate 'crash' in a section. You can show them the snapped bit in your pocket, bumbag, camelback etc etc. This is then all OK and above board, nothing canbe done as you will get a new plate ASAP on Monday morning when the shops open. A broken number plate can still get you a Quote Link to comment Share on other sites More sharing options...
02-apr Posted April 15, 2011 Report Share Posted April 15, 2011 Its a nightmare. I just took my old Lambretta for MOT and had to take the slightly smaller, 6 1/4 inch number plate off for an hour and put a full size one on. I would have thought that the Lambretta was old enough for the "old" size rules to apply, possibly even allowing a black plate with white letters. Quote Link to comment Share on other sites More sharing options...
gjbiker Posted April 15, 2011 Report Share Posted April 15, 2011 I don't suppose anyone has a copy of 'The Road Vehicles (Display of Registration Marks) Regulations 2001' by any chance? I've always wondered if the plate has to be fixed to the bike or if it could be worn by the rider (on a backpack for instance)? Daft idea perhaps but it would allow a full size plate to be displayed whilst on the road and no extra burden in the sections? GJ Quote Link to comment Share on other sites More sharing options...
pete_scorpa3 Posted April 15, 2011 Report Share Posted April 15, 2011 Saw a rider doing that very thing at the Colmore. Small plate on the bike, full size plate on his back pack. Quote Link to comment Share on other sites More sharing options...
charlie prescott Posted April 15, 2011 Author Report Share Posted April 15, 2011 Hi Guy's Done a bit more homework today. No excuse broken ,plates are illegal and will still get you a fine for display. Plates worn on the back of your jacket , is not part of the machine so when you walk away it is illegal. The only thing I have found that is available, and used on HGV trucks, and trailers, is a Spring clip device that holds the plate while in transit. Now this could be used, all you would need to do is remove the plate to attempt the section and then clip it back on for the next group, Simples I have still been told, that the fine is now Quote Link to comment Share on other sites More sharing options...
b40rt Posted April 15, 2011 Report Share Posted April 15, 2011 Think the spring clip devise is bigger than the plate, could be wrong. Quote Link to comment Share on other sites More sharing options...
charlie prescott Posted April 15, 2011 Author Report Share Posted April 15, 2011 Hi Guy's. This is the clip, it says you need two, but I am sure one would do. Number plate clip, square plate Ref: BF228 TrailerTek Price: Quote Link to comment Share on other sites More sharing options...
cabby Posted April 15, 2011 Report Share Posted April 15, 2011 I have still been told, that the fine is now Quote Link to comment Share on other sites More sharing options...
