searay175 Posted April 15, 2011 Report Share Posted April 15, 2011 Thanks for all the input on my "bleeding the clutch" post! I have taken care of that part and have now moved into the clutch pack itself. I had changed the gearcase oil which had atf in it and replaced it with 5w30 as recommended and it got worse. I removed the clutch discs/plates which were very sticky so I may put atf type f in as I read that it is thinner. The springs are within the specs. I have a spare clutch pack that cam with the bike that looks to have low use and may replace the sticky ones with that set. I also will check the plates for warpage.at what spec should I torque the clutch cover bolts? If there is any other areas to check out that I missed please add your input. Thanks again! Steve Quote Link to comment Share on other sites More sharing options...
mikee Posted April 15, 2011 Report Share Posted April 15, 2011 Don't run the 320 with ATF use a good 10w/40w oil. I ran mine with only four springs and it would only slip in 5th gear with a big handfull.Made rideing in the sections alot better as the clutch was very on off with all six springs in. The spring bolts just need to nipped up thight with a spanner. Quote Link to comment Share on other sites More sharing options...
jdhogg Posted April 16, 2011 Report Share Posted April 16, 2011 Don't run the 320 with ATF use a good 10w/40w oil. I ran mine with only four springs and it would only slip in 5th gear with a big handfull.Made rideing in the sections alot better as the clutch was very on off with all six springs in. The spring bolts just need to nipped up thight with a spanner. I had exactly the same problem with my 320 , for the price of them , get a seal kit for the slave cylinder ,its a new piston and seal , and the master cyclinder kit is cheap enough too, that way all done, i bought a new master cyclinder found one at the right price but same thing , sorted now. initially the clutch went from dragging badly ( no clutch at all) to slipping after done the above ,but had i checked the plates proparly would of seen no meat on em! solved that at the same time... the srpings where 60p each so replaced them too but i put all six back as per gas gas vids on you tube cheers jon Quote Link to comment Share on other sites More sharing options...
