Clutch Retaining Bolt
monty_jon
Has anyone had difficulty removing the clutch-retaining bolt from a TXT Pro?
The hex on the bolt is very shallow!
You have to use a new or dressed Allen (5mm off the end) wrench. A much used,
old Allen will strip it out (and other capscrews also). Be sure to replace it
with the same type bolt as the hollow portion acts as a breather passageway for
the transmission and the short head allows clearance for the end of the servo
cylinder ("top hat").
Some riders leave out the capscrew and stepped washer but I like to keep it in
as I think it contributes to clutch basket/hub stability.
Jon
