djfoxi Posted April 21, 2011 Report Share Posted April 21, 2011 Hi can anyone help my sherco 125 It was just ticking over and all of a sudden stoped i tried to kick it over and found the engine had gone very tight so i removed the barrel to find the piston was all in good order and no sign of seizure in the top end . But something in the bottom end was still tight i turned it by the flywheel a few times and it loosened any ideas !!!!!!!!!!! many thanks Quote Link to comment Share on other sites More sharing options...
lee harris Posted April 21, 2011 Report Share Posted April 21, 2011 prabably a main bearing has collapsted. common on shercos Quote Link to comment Share on other sites More sharing options...
djfoxi Posted April 22, 2011 Author Report Share Posted April 22, 2011 prabably a main bearing has collapsted. common on shercos many thanks you are absolutely right i striped the engine to find bearing cage had broken i was very lucky that the engine was only ticking over at the time that it broke and now real damage done Quote Link to comment Share on other sites More sharing options...
