3896 Posted April 21, 2011 Report Share Posted April 21, 2011 Carb is a24mm mikuni it is on a BSA bantam b175 problem is when choke is on it starts and runs but then when you take it off it dies has worked fine for ages but now stopped I have cleaned inside carb aswell any sugestions please will be moast gratefull Quote Link to comment Share on other sites More sharing options...
tony283 Posted April 21, 2011 Report Share Posted April 21, 2011 If it runs on the choke and dies when you take it off then the PILOT jet is BLOCKED. Tony Quote Link to comment Share on other sites More sharing options...
3896 Posted April 21, 2011 Author Report Share Posted April 21, 2011 Thank you is the pilot jett the one the needle goes to ? Thanks again much appreciated Quote Link to comment Share on other sites More sharing options...
3896 Posted April 21, 2011 Author Report Share Posted April 21, 2011 And how shall I clean it shall I blow out with the air line Quote Link to comment Share on other sites More sharing options...
tony283 Posted April 21, 2011 Report Share Posted April 21, 2011 (edited) The needle drops into the main jet and the pilot jet is located in front of the main jet. Blow compressed air through from below. Tony Edited April 21, 2011 by tony283 Quote Link to comment Share on other sites More sharing options...
3896 Posted April 21, 2011 Author Report Share Posted April 21, 2011 The needle drops into the main jet and the pilot jet is located behind the main jet to the rear. Blow compressed air through from below. Tony Quote Link to comment Share on other sites More sharing options...
3896 Posted April 21, 2011 Author Report Share Posted April 21, 2011 Thanks Tony just makin sure don't want to ruin it my dad would go mad Quote Link to comment Share on other sites More sharing options...
3896 Posted April 22, 2011 Author Report Share Posted April 22, 2011 Thanks fine now works a treat worked on my friends mini moto to thanks again Quote Link to comment Share on other sites More sharing options...
