tricks Posted April 22, 2011 Report Share Posted April 22, 2011 Few questions.. Wheres the cheapest place to get them? and is it best to stick with OEM Yamaha plates? And i read somewhere that YZ125 plates fit!??.. is that true or did i dream it? cheers Quote Link to comment Share on other sites More sharing options...
kamiture Posted April 23, 2011 Report Share Posted April 23, 2011 YZ125 plates fit as shape.However,there is functionally problem. I have tested 5DH-16321-00(-04YZ15) as measures with sticking the clutch before. It canceled sticking but caused slipping. 3XJ-16321-00(05-YZ15)seems fit too,but I don't know whether it causes the problem or not. I using 1KT-16321-00 and elf HTX740 now,they don't cause sticking nor slipping. Quote Link to comment Share on other sites More sharing options...
tricks Posted May 11, 2011 Author Report Share Posted May 11, 2011 Thanks Kam, And sorry for this late reply, I ended up buying the oem 1KT plates. My clutch has been engaging fine, and no sticking from cold.. but the main problem has been slipping [dragging] in high gears normally 3rd up wards when warm, so hopfully new plates will cure it, although the old ones don't look worn out. Nothing seems to be straight forward on the scorpa Quote Link to comment Share on other sites More sharing options...
drake Posted May 22, 2011 Report Share Posted May 22, 2011 Thanks Kam, And sorry for this late reply, I ended up buying the oem 1KT plates. My clutch has been engaging fine, and no sticking from cold.. but the main problem has been slipping [dragging] in high gears normally 3rd up wards when warm, so hopfully new plates will cure it, although the old ones don't look worn out. Nothing seems to be straight forward on the scorpa Maybe you should try adjusting it correctly. Apparently this works and only takes a minute or two Quote Link to comment Share on other sites More sharing options...
tricks Posted May 22, 2011 Author Report Share Posted May 22, 2011 Oi get back on the Sherco threads you 'ya secret scorpa lover.. It needed new plates AND adjusting Quote Link to comment Share on other sites More sharing options...
